Small URL Generator: Part 1
The Small URL Generator was born partly out of curiosity and partly out of necessity. It started off when I was in our IT department here at F5 when a coworker and I began discussing what it would ta...
Published Aug 11, 2010
Version 1.0George_Watkins_
Historic F5 Account
Joined September 17, 2008
Jun 21, 2013
Adrian, what exactly isn't working. Are you not seeing anything when you submit the table name? Or is it just that the controls don't work. The code is pretty basic HTML so it shouldn't have any problems with specific browsers.
