Log Bypass for BIG-IP Monitor Traffic
Monitors are a part of just about any infrastructure that needs to be highly available. BIG-IP has a whole host of different monitoring options for keeping tabs on servers. It's important for your BI...
Published May 01, 2012
Version 1.0Colin_Walker_12
Historic F5 Account
Joined May 12, 2005
George_Watkins_
May 03, 2012Historic F5 Account
In theory yes, but that would require someone to somehow be aware of this
monitoring string. If you are worried about this scenario, it is very easy
to block external requests with this User-Agent with an iRule:
log local0. "[IP::client_addr]:[TCP::client_port]: User-Agent: [string
tolower [HTTP::header "User-Agent"]] requested [HTTP::host][HTTP::uri]"
if { [string tolower [HTTP::header "User-Agent"]] contains "F5 BIG-IP
Monitor"} {
log local0. "[IP::client_addr]:[TCP::client_port]: Rejected
request"
reject
You can also add this logic to the Apache server config. Since you've already set an environment variable for the monitoring User-Agent we can reuse that to enforce access. You'll want to locate the VirtualHost's Allow and Deny directives and change the order and parameters to block external monitoring requests:
Order Deny,Allow
Deny from env=monitor
set subnet or addresses of BIG-IP self-IPs
allow from 10.40.0.0/16
Great question. Hope that helps!
