iCR Python Module for iControl REST
Problem this snippet solves:
This is a python module to simplify using iControl REST.
Install using pip:
pip install iCR
or retrieve from https://pypi.python.org/pypi?:action=display&name=iCR&version=2.1
As simple as:
#!/usr/bin/env python from iCR import iCR bigip = iCR("172.24.9.132","admin","admin") virtuals = bigip.get("ltm/virtual") for vs in virtuals['items']: print vs['name']
This prints out a list of Virtual Servers.
Supported methods:
init(hostname,username,password,[timeout,port,icontrol_version,folder,token,debug])
-> returns data or Falseget(url,[select,top,skip,filter])
-> Used to retrieve large datasets in chunks. Returns data or Falsegetlarge(url,size,[select])
-> returns data or Falsecreate(url,data)
-> returns data or Falsemodify(url,data,[patch=True])
-> returns True or Falsedelete(url)
-> file is a local file eg /var/tmp/test.txt, returns True or Falseupload(file)
-> files are located in /shared/images, returns True or Falsedownload(file)
-> files is an array containing paths to cert and key. Returns name of cert or Falsecreate_cert(files)
-> name is the name of a policy. Returns an array of IDs or Falseget_asm_id(name)
-> name is the name of the partition and policy. eg /Common/test_policy. This reduces the need to retrieve an array of hashes from the BIG-IP. Returns a string.create_hash(name)
-> this retrieves a BIG-IP token based on the username and password and sets it as the token in use. Returns the token ID or Falseget_token()
-> This deletes the object token from the BIG-IP and from the objectdelete_token()- create_transaction() -> creates a transaction and returns the transaction number ID as a string, or False. Subsequent requests will be added to the transaction until commit_transaction is called. Transaction ID is stored in object.transaction
- commit_transaction() -> Commits the transaction stored in object.transaction. Returns True or False
- command(args,[cmd]) -> Runs a command using the arguments string args. Returns the returned output or True on success or False on failure.
- Note: Be sure to double-escape single quotes eg \\' and single escape double quotes eg \"
- cmd options are ping/save/load/restart/reboot
Module Variables:
- icr_session - the link to the requests session
- raw - the raw returned JSON
- code - the returned HTTP Status Code eg 200
- error - in the case of error, the exception error string
- headers - the response headers
- icontrol_version - set this to specify a specific version of iControl
- debug - boolean True or False to set debugging on or off
- port - set the port ( 443 by default )
- folder - set this to create in a specific partition
- token - use this to set a specific token. If this is set, it will be used instead of basic auth
- select - use this with get to select the returned data
- top - use this with get to return a set number of records
- skip - use this to skip to a specific record number
- transaction - stores the Transaction ID
How to use this snippet:
Examples
Setup a REST connection to a device
#!/usr/bin/env python from iCR import iCR bigip = iCR("172.24.9.132","admin","admin",timeout=10)
Create a Virtual Server
vs_config = {'name':'test_vs'} createvs = bigip.create("ltm/virtual",vs_config,timeout=5)
Retrieve the VS we just created
virt = bigip.get("ltm/virtual/test_vs",select="name") print "Virtual Server created: " + virt['name']
Set the timeout
bigip.timeout = 20
Now delete the VS we just created
delvs = bigip.delete("ltm/virtual/test_vs")
Retrieve ASM policy to ID mapping
policies = bigip.get("asm/policies",select="name,id")
Print a table of ASM policies with learning mode
print print "Policy Name Learning Mode" print "------------------------------------------" for item in policies['items']: enabled = bigip.get("asm/policies/" + item['id'] + "/policy-builder",select="learningMode") print '{:32}'.format(item['name']) + enabled['learningMode']
File upload
fp = "/home/pwhite/input.csv" if bigip.upload(fp): print "File " + fp + " uploaded"
File download
file="BIGIP-12.1.2.0.0.249.iso" download = bigip.download(file) if not download: print "File " + file + " download error"
SSL Certificate creation
In different folder
bigip.folder = "TestFolder" files = ("TestCert.crt","TestCert.key") cert = bigip.create_cert(files) if cert: print "Certificate " + cert + " created"
Turn on debugging
bigip.debug = True
Retrieve ASM policy IDs
asm = bigip.get_asm_id("dummy_policy") print len(asm) + " IDs returned" print "ID: " + str(asm[0])
Convert an ASM policy name to hash
hash = bigip.create_hash("/Common/test-policy") enabled = bigip.get("asm/policies/" + hash + "/policy-builder",select="learningMode") print '{:32}'.format(item['name']) + enabled['learningMode']
Retrieve and use a token
bigip.get_token()
Delete the token
bigip.delete_token()
Developed on Python 2.7 but works with v3. Works on TMOS 11.6 onwards though some features may not be implemented, such as tokens. If you use this and have found bugs, would like to discuss it or suggest features then please PM me on DevCentral.
Tested this on version:
13.019 Comments
- pirusti
i am using iControl Rest 2.4 downloaded from https://pypi.org/project/iCR/.
while using wideips = bigip.getlarge("gtm/wideip/a", xxx) , where xxx is the size of chunk, i would like to understand the limit of chunk size.
if i use wideips = bigip.get("gtm/wideip/a") , it works if i have 200-300 hundred wideips, but in case you have +10k wideips it gives you Error 500, AsyncContext timeout.
what is the best way to download via api the /mgmt/tm/gtm/wideip/a ?
- tonygruz
typeerror: 'module' object is not callable
This error occurs when the python compiler gets confused between function name and module name and try to run a module name as a function. This error statement TypeError: 'module' object is not callable is raised as you are being confused about the Class name and Module name. The problem is in the import line . You are importing a module, not a class. This happend because the module name and class name have the same name .
If you have a class MyClass in a file called MyClass.py , then you should write:
from MyClass import MyClass
In Python , a script is a module, whose name is determined by the filename . So when you start out your file MyClass.py with import MyClass you are creating a loop in the module structure. Also, note that this usually happens when you import any kind of module as a function.
- PeteWhite
Employee
Updated to v2.1 which adds transactions and is refactored to make more sense internally. Included examples etc as well.
- PeteWhite
Employee
Hi liuyi6324, i've tested this with v3 and it seems to work OK - i've changed the print and except commands.
- PeteWhite
Employee
Hi liuyi6324, I have developed and tested this on Python 2 but i can't see why it wouldn't work on v3. The only issue might be the debug I guess - print is different in v3. If you can test it and let me know I will develop it so that it works in v3 as well. This will work in all versions after 11.5 as it uses the basic REST functionality.
- liuyi6324_37637
Hi Peter, does it only work on Python2 and Version13.0 or later?
- PeteWhite
Employee
Updated the module to 1.9 and added get_token and delete_token functions.
- PeteWhite
Employee
Updated to fix a bug with modify not JSONifying the provided data
- PeteWhite
Employee
I've updated the module to add some functionality like uploading and downloading files as well as creating SSL certs and profiles, and retrieving an ASM ID from a policy name. Feel free to try it out and let me know what you think.
- PeteWhite
Employee
Glad you've got it working Tom, i'll take a look into this. Feel free to let me know of any improvements that can be made.
