mikand_61525
Nov 23, 2008View current bandwidth for particular interface
Is it possible (with some built in command or such) to through ssh see how much bandwidth (in mbit/s or so) a F5 BigIp unit utilizes over a particular interface?
ifconfig can be used to see number of packets and tcpdump can be used to capture the actual traffic but I want for debugging purposes see how many mbit/s there are for a particular interface.
- hoolio
Maybe you could get this via SNMP? I'm not too sure on that. 'b interface' and 'b vlan' will give you cumulative packets and bits in/out, but not current throughput.
Aaron - mikand_61525
Hmm perhaps I could use "b interface" and "b vlan" in order to create a script that will count the diff in numbers of bytes passing through each second and this way get sort of a bandwidth meter (basically its for debugging purposes to see approx how many mbit/s there is on a particular interface). But it would be cooler if such thing already existed :) - Hamish
Cirrocumulus
Can you get access to a copy of Cacti? Or if no existing one, do you have a box (Or even a VMWare session) that you could run something like EZCacti on? Then just poll the F5 with Cacti via SNMP and you'll be away laughing.
There's some templates floating around here for LTM/GTM specific stuff, and some shorter templates with specific graphs for some stuff I did for cacti as well to extend them.
Hamish. - mikand_61525
Sure I could use cacti or similar but that doesnt really solve my issue of being able to in cli see the approx bandwidth of a particular interface.
Another problem with using cacti and similar is the latency of when the data will be displayed. I simply just want a snabshot of how many mbit/s a particular interface currently uses, not the 5 minute average etc.
Something like "b show bandwidth " would be cool. - JRahm
Admin
You can check the status from any OS with Perl, just make sure the Net::SNMP module is installed. The interface map is from a 6400, if you have other interface names, you'll need to append them to the map. The end of the oids are ascii representations of the interface characters, and are preceded by the number of characters, so 1.1 in ascii is 3.49.46.49, and 1.10 is 4.49.46.49.48, etc.
[code]
!/usr/bin/perl -w
use strict;
use Net::SNMP qw(:snmp);
my $usage = "ltm_intStat.pl ";
die "Usage: $usage\n" if $ARGV != 3;
my $host = $ARGV[0];
my $snmp_comm = $ARGV[1];
my $int = $ARGV[2];
my $interval = $ARGV[3];
chomp ($host , $snmp_comm , $int , $interval);
my $ltm_InBytes_Index = "1.3.6.1.4.1.3375.2.1.2.4.4.3.1.3";
my $ltm_OutBytes_Index = "1.3.6.1.4.1.3375.2.1.2.4.4.3.1.5";
my %int_map = ("1.1"=>".3.49.46.49",
"1.2"=>".3.49.46.50",
"1.3"=>".3.49.46.51",
"1.4"=>".3.49.46.52",
"1.5"=>".3.49.46.53",
"1.6"=>".3.49.46.54",
"1.7"=>".3.49.46.55",
"1.8"=>".3.49.46.56",
"1.9"=>".3.49.46.57",
"1.10"=>".4.49.46.49.48",
"1.11"=>".4.49.46.49.49",
"1.12"=>".4.49.46.49.50",
"1.13"=>".4.49.46.49.51",
"1.14"=>".4.49.46.49.52",
"1.15"=>".4.49.46.49.53",
"1.16"=>".4.49.46.49.54",
"2.1"=>".3.50.46.49",
"2.2"=>".3.50.46.50",
"2.3"=>".3.50.46.51",
"2.4"=>".3.50.46.52",
"mgmt"=>".4.109.103.109.116");
my $ltm_intBytesIn = $ltm_InBytes_Index . $int_map{$int};
my $ltm_intBytesOut = $ltm_OutBytes_Index . $int_map{$int};
my ($session, $error) = Net::SNMP->session(
-hostname => $host,
-community => $snmp_comm,
-port => 161,
-version => 'snmpv2c',
-nonblocking => 0
if (!defined $session)
print "Received no SNMP response from $host\n";
print STDERR "Error: $error\n";
exit -1;
Get first instance
my $oids_1 = $session->get_request(
-varbindlist =>
[$ltm_intBytesIn, $ltm_intBytesOut] );
sleep $interval;
Get second instance
my $oids_2 = $session->get_request(
-varbindlist =>
Calculate Rates
my $rate_in = ($oids_2->{$ltm_intBytesIn} - $oids_1->{$ltm_intBytesIn})*8 / $interval;
my $rate_out = ($oids_2->{$ltm_intBytesOut} - $oids_1->{$ltm_intBytesOut})*8 / $interval;
Round to integer
$rate_in = int($rate_in + .5);
$rate_out = int ($rate_out + .5);
my $rate_total = $rate_in + $rate_out;
Print Results
print "\n\n\t$rate_in bits/second (IN)\n";
print "\t$rate_out bits/second (OUT)\n";
print "\t$rate_total bits/second (TOTAL)\n";
[/code]
I ran this successfully with ActiveState perl on my XP machine:
[blockquote]
C:\dev\perlscripts>ltm_intStat.pl my.bigip.domain.com public mgmt 5
1429 bits/second (IN)
205 bits/second (OUT)
1634 bits/second (TOTAL)
[/blockquote] - JRahm
Admin
Argh! I'll have to fix this and add as attachment. Standby... - JRahm
Admin
OK, the perl script is attached. - JRahm
Admin
I cleaned the script up a little bit and added the ability to loop through all interfaces as well. It is posted in the wiki:
http://devcentral.f5.com/wiki/default.aspx/AdvDesignConfig/BigIPRemoteInterfaceBandwidthMonitor.html - IT_Support_5777
Good afternoon!
Is this something that could be extended to give the total bandwidth utilized by a particular URL? Where could I go to find the answer to that?
Thank you.
TK - Hamish
Cirrocumulus
Bandwidth per URL? Or bandwidth per Virtual Server?
Per VS is quite easy. Its in the stats for each VS. You simply need to pull the correct OID. The cacti templates on devcentral can do this for you.
Per URL is a bit harder. You'd need to use custom stats profiles and an iRule to do the counts and update the stats. Then pull the results with the correct SNMP OID (Or iControl). That would require a bit more thought, and would be a custom job per website.
