Jay_Allison_400's avatar
Jay_Allison_400
May 22, 2007
URI replace help
quite simply i'm trying to replace certain characters in a URI path with other characters, this was my first stab at it, doesn't seem to be working, any suggestions?
URI::path [string map {~ ~ZZ % ~} [HTTP::uri]]
Tried a few other variations including backslashes and this
URI::path [string map {~ ~ZZ % ~} URI::path]
haven't hit on one one that has worked yet
  • So I got this to work fine
    HTTP::uri [string map {\~ \~ZZ \% \~} [HTTP::uri]]
    but i really only want to affect the URI::path
  • Try replacing the uri command with the path command in your string map, then append the query when you set your new uri:
    HTTP::uri [string map {\~ \~ZZ \% \~} [HTTP::path]][HTTP::query]
