safiyet_80777's avatar
safiyet_80777
Apr 04, 2011
scheduled task problem
I want to form a scheduled task. I want to use perl script. For testing cron&crontab, I write a basic script which create a file and write something to the file.
root crontab -l
cron tab for root
1-59/30 * * * * /usr/bin/diskmonitor
*/1 * * * * perl /root/createfile
I suppose that my script should work every minute. I changed it to * * * * * perl /root/createfile for testing but for both cases my script can not run and data.txt was not created.
My script is:
!/usr/local/bin/perl
open (MYFILE, '>>data.txt');
print MYFILE "Bob\n";
close (MYFILE); (MYFILE);
I can not find the problem. I supposed that cron & crontab should be working in f5. Is it correct?
Thanks...
  • We use scripts when we form a home crontab with "crontab -e -u " command. our scripts works well. But we can not run scripts in "crontab -l". Can not we use these directories for our scripts? I supposed that the problem is about root user and its permissions. Is this correct?
