Juliano_Luz_479
10 years agoProblem with SNAT configuration
I´m trying to configure a SNAT for Cisco ISE Change Of Authorization (COA) . The goal is to have the virtual address from the load balance appearing as the source of all COA connections. This way I don´t need to add each policy server address to the NADs. I´m using LTM 11.0.0. I configured the SNAT as shown below:
ltm snatpool /Sisop-Linux/radius_coa_snat {
members {
/Sisop-Linux/172.10.10.10 /*address used as origin
ltm virtual /Sisop-Linux/vs-isepsn-coa {
destination /Common/0.0.0.0:1700
ip-protocol udp
mask any
profiles {
/Common/udp { }
translate-address disabled
translate-port disabled
vlans {
/Common/v811-pool-net-services /*vlan where the police servers are located
vlans-enabled
The COA traffic never reaches the destination. A tcpdump on the balance shows that traffic is entering the "v811-pool-net-services" vlan but it doesn´t exit.
Can anyone help me?
- Josiah_39459Historic F5 AccountWhat's the destination? Does it match a route? If there's no route found in the tmm routing table, it won't exit.
