Carlos_Hernand7
Sep 27, 2011Problem with IIS 6 + WMI Monitor
Hello all,
Recently I have configured the WMI monitor & Data Gathering Agent in Windows 2008 + IIS 7. Everything worked like a charm.
I am trying to do the same with a Windows 2003 + IIS 6 and I haven't been able to make it work. I followed all the steps in the Configuration Guide but it did not work at all. The node is marked down as soon as the monitor is assigned to it.
I enabled the logging for WMI performance monitor using this article:
http://support.f5.com/kb/en-us/solutions/public/4000/600/sol4690.html
And when I checked the log the only thing I can see is:
"Target: http://XXX.XXX.XXX.XXX:80/scripts/F5Isapi.dll?GetCPUInfo (ID/Pwd: [email protected]/Mypassw0rd)
Failure processing HTTP request"
We are using LTM ver 10.2.0 on a 6400 D63 hardware.
¿Any ideas on how to troubleshoot this issue?
Thanks a lot for your assistance.
Carlos
- Miller_22125Historic F5 AccountIIS 7 and IIS 6 have different Data Gathering Agents. You should be able to use the F5.IsHandler.dll on both, but for it to work on IIS 6 you will need to install the .Net framework. It is better to use f5isapi.dll if you are running IIS 6.
Also, there are two versions of f5isapi.dll - one for 32bit and one for 64bit. Be sure you are using the correct one. - Helen_Johnson_1Historic F5 AccountHi Carlos,
Were you ever able to resolve this issue? Please let us know at your earliest convenience.
Cheers,
Helen
