George_33482
Mar 27, 2012LC load balancing three links through a router
Hello,
I have a requirement to configure LC in order to load balance three ISPs through a router.
LAN -> LC -> Router -> 3 Internet ISP links.
I cannot change the customer's topology LAN- >Router->3 Internet ISP links.(because the topology is much more complicated).
Any idea how to do this???
I configured LCs in which the Links are directly connected or there is one link on each router.
Thank you in advance for your support.
Regards,
George
- Cholito_15468
LAN => Router => LC => 3 ISP links - George_33482
i cannot do this, the links are actually WAN links and they are connected to the Router through a serial cable and not ethernet, as i said the topology much more complicated.
Any ideas on how to make the setup/design work:: LAN -> LC -> Router -> 3 links ???
Regards,
George - Cholito_15468
first,
I recommend is that you have 3 routers, there is no logic to have 3 links in a router.
But can you do the following.
configure a trunk link between the router and LC.
there you will have 3 links.
You know very well the networking so you wont have problems.
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos_management_guide_10_1/tmos_trunks.html - Cholito_15468
first,
first,
hi george, you can configured bridge interface
http://www.cisco.com/en/US/tech/tk331/tk660/technologies_tech_note09186a0080094471.shtml
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t3/feature/guide/dtbridge.html
you have LAN => LC =dot1q=> ROUTER => ISP - George_33482
Thank you i will give it a try.This was my initial thought.
Regards, - George_33482
Regards,
