t-roy
Nov 22, 2011inserting X-Origin-Host heade when using catch command
iRule's purpose:HTTP::header insert lws X-Origin-Host "[HTTP::host]"I know how to do this if I set a variable then add once my pool is selected, but I can't figure out how to do it using catch. Any help is appreciated!
rewrite some URIs to /
rewrite some hosts to start with www
send some URIs to my non-default pool but putting them in a data-group like "foo" := "foopool",
My problem: If my last if statement matches I would like to insert an X-Origin-Host header like so:
if {[ class match -value [string toupper [HTTP::uri]] starts_with WWW-PREIMP.FOO.CA-URIREDIR] ne "" } {
HTTP::uri "/"
if {
[catch {[class match -value [string toupper [HTTP::host]] starts_with WWW-PREIMP.FOO.CA-PATHREDIR] } ]
HTTP::respond 301 Location "]"
if {
[catch { pool [class match -value [string toupper [HTTP::uri]] starts_with FOO.CA-REDIR] } ]
pool WWW-PREIMP.FOO.CA
Thanks!
Troy
- hoolio
Hi Troy,
So you're trying to use catch to handle errors when inserting the header? How about something like this:if {[HTTP::host] ne ""}{ catch {HTTP::header insert lws X-Origin-Host "[HTTP::host]"} }
Aaron - nitass
Employee
e.g.[root@ve1023:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.79:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve1023:Active] config b pool foo list pool foo { members 200.200.200.101:80 {} } [root@ve1023:Active] config b pool foopool list pool foopool { members 200.200.200.102:80 {} } [root@ve1023:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { if {[class match -- [string toupper [HTTP::host]] starts_with WWW-PREIMP.FOO.CA-PATHREDIR]} { HTTP::respond 301 Location "http://www.[HTTP::host]" } elseif {[class match -- [string toupper [HTTP::uri]] starts_with WWW-PREIMP.FOO.CA-URIREDIR]} { HTTP::uri "/" } if {[class match -- [string toupper [HTTP::uri]] starts_with FOO.CA-REDIR]} { catch {HTTP::header insert lws X-Origin-Host [HTTP::host]} catch {pool [class match -value [string toupper [HTTP::uri]] starts_with FOO.CA-REDIR]} } } } [root@ve1023:Active] config b class WWW-PREIMP.FOO.CA-PATHREDIR list class WWW-PREIMP.FOO.CA-PATHREDIR { "ABC.COM" } [root@ve1023:Active] config b class WWW-PREIMP.FOO.CA-URIREDIR list bclass WWW-PREIMP.FOO.CA-URIREDIR { "/TEST" } [root@ve1023:Active] config b class FOO.CA-REDIR list class FOO.CA-REDIR { "/FOO" { "foopool" } } 1 [root@ve1023:Active] config curl -I http://abc.com/abc HTTP/1.0 301 Moved Permanently Location: http://www.abc.com Server: BigIP Connection: Keep-Alive Content-Length: 0 2 [root@ve1023:Active] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 172.28.19.253(45755) <-> 172.28.19.79(80) 1322048483.6894 (0.0031) C>S --------------------------------------------------------------- HEAD /test/abc HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8r zlib/1.2.3 libidn/0.6.5 Host: www.abc.com Accept: */* --------------------------------------------------------------- New TCP connection 2: 200.200.200.10(45755) <-> 200.200.200.101(80) 1322048483.6904 (0.0009) C>S --------------------------------------------------------------- HEAD / HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8r zlib/1.2.3 libidn/0.6.5 Host: www.abc.com Accept: */* --------------------------------------------------------------- 3 [root@ve1023:Active] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 172.28.19.253(47562) <-> 172.28.19.79(80) 1322048588.1531 (0.0019) C>S --------------------------------------------------------------- HEAD /foo/abc HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8r zlib/1.2.3 libidn/0.6.5 Host: www.abc.com Accept: */* --------------------------------------------------------------- New TCP connection 2: 200.200.200.10(47562) <-> 200.200.200.102(80) 1322048588.1553 (0.0010) C>S --------------------------------------------------------------- HEAD /foo/abc HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8r zlib/1.2.3 libidn/0.6.5 Host: www.abc.com Accept: */* X-Origin-Host: www.abc.com --------------------------------------------------------------- - t-roy
awesome!!! nitass your solution is exactly what I had in mind. Going to test in my lab but I think that should work perfectly.
thanks guys!!! - nitass
Employee
you are welcome. :-)
