Generic Host HTTPS monitor
I'm attempting to set up a pool with two HTTPS web applications. The pool members are generic hosts listening on 443 and not behind an LTM.
When I assign the built-in HTTPS pool, both pool members respond without issue. However, when I create a custom monitor where I expect a 200 OK response, the pool members are marked offline.
(I tested in my LTM lab environment and using the same configuration with the custom HTTPS monitor and the pool members were successful.)
Here are the LTM and GTM monitors, respectively:
ltm monitor https https_get_monitor {
adaptive disabled
cipherlist DEFAULT:+SHA:+3DES:+kEDH
compatibility enabled
defaults-from https
description stuff
destination *:*
interval 30
ip-dscp 0
recv "HTTP/1.(0|1) (1|2|3|4)"
recv-disable none
send "GET / HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n"
time-until-up 0
timeout 91
gtm monitor https https_get_monitor {
defaults-from https
destination *:*
interval 30
probe-timeout 5
timeout 120
}1 Reply
- Dario_Garrido
Noctilucent
Hello Zuke.
To set a custom HTTPS with specific host header you can set 3 different https monitors
ltm monitor https https_1 { adaptive disabled defaults-from https destination *:* interval 5 ip-dscp 0 recv 200\sOK recv-disable none send "GET / HTTP/1.1\r\nHost: myapp1.domain.com\r\nConnection: Close\r\n\r\n" time-until-up 0 timeout 16 } ltm monitor https https_2 { adaptive disabled defaults-from https destination *:* interval 5 ip-dscp 0 recv 200\sOK recv-disable none send "GET / HTTP/1.1\r\nHost: myapp2.domain.com\r\nConnection: Close\r\n\r\n" time-until-up 0 timeout 16 } ltm monitor https https_3 { adaptive disabled defaults-from https destination *:* interval 5 ip-dscp 0 recv 200\sOK recv-disable none send "GET / HTTP/1.1\r\nHost: myapp3.domain.com\r\nConnection: Close\r\n\r\n" time-until-up 0 timeout 16 }And finally configure the pool to consider UP if at least one of them is OK (including all the monitors in the list).
ltm pool mypool { members { 172.16.20.1:https { address 172.16.20.1 session monitor-enabled state up } 172.16.20.2:https { address 172.16.20.2 session monitor-enabled state up } 172.16.20.3:https { address 172.16.20.3 session monitor-enabled state up } } monitor min 1 of { https_1 https_2 https_3 } }BTW, use "200\sOK" as received string.
REF - https://support.f5.com/csp/article/K5917
Let me know if this is helpful.
KR,
Dario.
