Adam_409
Jun 06, 2011Connections Limitation
- Adam_409
Dear Dev Team,
We have two nodes in a pool.
Is it possible to limit the number of connections/requests from the F5 to each server to 500 per server at same time?
Best Regards,
Adam - nitass
Employee
doesn't connection limit per pool member work? - Adam_409
Could someone help on this? - Adam_409
Pls let me know what will be best option to this?
Is it best to do it via iRule ? or through connection limit via GUI? - nitass
Employee
is this applicable?
specifying a connection limit
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm_configuration_guide_10_1/ltm_pools.html1219910
sol8457: Connection limits configured on pool members or nodes within a Clustered Multi-Processing configuration are incorrectly enforced per TMM instance
http://support.f5.com/kb/en-us/solutions/public/8000/400/sol8457.html
cheer! - Colin_Walker_12Historic F5 AccountIf you can achieve what you're looking for via the standard connection limit option in the GUI/CLI, then I recommend doing it that way. You certainly could do this via an iRule but it will be more overhead and more work to maintain long term than a simple option in the config would be.
Colin
