Most monitor alerts include the IP address of the device that performed the probing. In the example below you can see that GTM delegated to the prober at 52.40.245.229, and it reported back with a failure.
Apr 9 00:55:46 10.5.32.15 Apr 9 00:55:46 denbip2000gtm01 alert gtmd[14902]: 011a4003:1: SNMP_TRAP: Pool /Common/my.example.net member my_example_net_https_vs (ip:port=1.2.3.4:443) state change green --> red ( Monitor /Common/https_ecomdb_keepalive from 52.40.245.229 : connect: protocol mismatch search result false) host = 10.5.32.15 source = udp:514 sourcetype = syslog
But in some monitor alerts the probe source is not shown. Notice in the example below it only shows “from gtmd”. Does anyone know what that means?
Apr 6 07:50:31 10.34.32.15 Apr 6 07:50:31 thwbip2000gtm01 alert gtmd[14695]: 011a4003:1: SNMP_TRAP: Pool /Common/token.example.com_lgt member token_example_com_lgt (ip:port=5.6.7.8:443) state change green --> red ( Monitor /Common/token_https from gtmd : state: timeout) host = 10.34.32.15 source = udp:514 sourcetype = syslog
