What Loadbalancing method to use ? If someone ask on what basis you select a particular loadbalacing method for particular or different applications.
Could plz provide the example based on if I use a HTTP , HTTPS & FTP server ? What loadbalancing method could I prefer for each.
Load balancing methods depends on your server capacity and processing power. It does not depend on your virtual server.
See Specifying the load balancing method section in this article.
This depends on application architecture and hardware requirements. let say you have hardware with same specifications then Least Connection method is recommended. If there is any difference between specs then you can use Ration based on members/nodes.
Ex: Round Robin :- Same hardware & Same Response time from application/DB for all requests
Least connection :- Same hardware & different Response time from application/DB for requests.
