Having an issue passing traffic from F5 BigIP to internal/external network. Both network’s are using tagged VLAN’s. I have configured BigIP to use the same VLAN number and assigned a Self IP to the same VLAN subnet. The ICMP monitors show all objects as down. From BigIP command line I am able to ping all self IP’s and Virtual Servers, but nothing outside of BigIP. TCPDump shows arp request, but no response. Configuration is as follows;
96.193.25.1 Default Gateway
VLAN 900
96.193.25.21 Virtual Server
96.193.25.17 Self IP
F5 LTM/LC
172.18.7.10 Self IP
VLAN 17
172.18.7.63 Server
Any help would be greatly appreciated. I am sure I am missing something simple.
Assuming the 172.18.7.10 self IP is on the same subnet as the 172.18.7.63, you shouldn’t need routing to ping between the two IP’s.
I wonder if this might be a problem with the VLAN or trunk configuration between LTM and the switch(es). If there aren’t trunks, would you need to use tagged VLANs on LTM? Any thoughts on that angle, Chris?
Aaron
Aaron - I’ve never had that as a setup before (tagged port on one side, not tagged on other) but could see that as a problem. If you’re configured as a trunk on the F5 but not as a portchannel on the switch, that could most definitely cause issues. I’d start off by changing to an untagged port to see if that changes anything…and if the trunk configs are different, try and standardize it.
Chris I found the issue(I think you mentioned it earlier but I didnt catch it). VLAN 998 is a tagged interface, but it is not a trunk on the switch side like 1.1. When changed VLAN 998 to untagged all the health monitors went to green. I am able to ping on VLAN 998. Thanks for all your help!
Gotcha…so from the F5, you were sending a vlan tag but the switch wouldn’t get that…makes sense. Glad to hear it’s working for you.
