Hi
… I have active and standby in v. 9.3.1 and use VLAN group and have a problem with sync
here is detail …when use command ping peer
Active will lost packet around 90% (have problem)
Standby will lost packet around 10% (no problem)
So when Active want to sync to peer .. Sync is failed
when I see ARP table … In standby unit I see MAC and vlan (internal) correct
but in Active unit I see MAC correct but Vlan is external ???
So I see when Active ping peer … it’s send packet through vlan external (actually should be internal) but problem is IP (both primary self and peer self) is in same address space
How to work out?
Thank you in advance
