Virtual IP
Can we use a different virtual ip for same server
This is possible. You could define a network range for example, so the VS will listen on multiple ip adresses. On top of that you could also add an iRule which will only accept traffic from a selection of ip adresses.
Then again why not create multiple virtual servers that use the same pool? Maybe you could give us a bit more context to work with?
