we have been running big-ip 10.2.2 build 763.3 final on vmware esx 4.1.0 build 260247 for many months without issue, but recently we migrated to esx 5.0.0 build 469512 and all of our pool members went down! i logged on to the BIG-IP command line and found that i was unable to ping any members (even though they’re in the same subnet)
after a lot of panic and troubleshooting, we migrated the BIG-IP back to a vmware host running vmware esx 4.1.0 build 260247 and it started working again!
i’m going to log this with support, but i wondered if this is a known problem? or if there’s an faq page which states which versions of vmware are supported for BIG-IP virtual edition?
thanks nitass. yes, it’s there in black and white but unfortunately it didn’t work
i’ve logged a call with f5, but i wonder if we have uncovered some sort of bug? the BIG-IP unit loaded up fine and i was able to logon to the management interface, but it simply wouldn’t pass traffic to the back end pool members. as soon as we put it back on a esx 4.1.0 it worked fine (without making any changes at all on BIG-IP)
the strange thing is, the flexible virtual nic used for management continued to work, but the vmx net 3 nic used for application traffic stopped working
thanks for the info. i don’t think the manual says you need a specific hotfix, but thanks for letting me know. i’m also awaiting the official response from the ticket that i have logged with f5
