Hi all,
Is it possible to perform following redirection using iRules?
http://www.example.com → node1 and node2 http://www.example.com/external → node3 and node4 (and user sees http://www.example.com/external/… in the browser URL address bar)
I’m to iRules and sorry for the newbie question.
Thanks a lot. /ST Wong
Try this, assuming pool node34 is defined with your nodes 3 and 4 as members, and pool node12 is defined with your nodes 1 and 2 as members:
if { [string tolower [HTTP::host]] equals "www.example.com" } {
if { [string tolower [HTTP::uri]] equals "/external" } {
pool node34
else {
pool node12
Also keep in mind this isn’t redirection, only pool selection based on the client’s request. No redirection should be needed here.
Sorry that I didn’t make the question accurate enough.
In this case, node3/node4 don’t know the uri /external/. I’ve to strip the /external/ part and pass the rest of uri to node3 and node4, then add it back in response to client. Is it possible? Thanks a lot.
Sure, just a simple change necessary to hide the /external from the nodes:
http::uri "/"
pool node34
else {
pool node12
Thanks, but seems I also have to rewrite the uri in HTTP response so that user’s browser will see http://www.example.com/external/… no matter what content is returned. I tried to do following but seems didn’t work.
when HTTP_RESPONSE {
STREAM::disable if {[HTTP::header value Content-Type] contains “text”}{ STREAM::expression {@www.example.com/@www.example.com/external/@} STREAM::enable } }
Thanks.
