upgrade vcmp guest at the same time on the same slot impact
hi everyone
Upgrade vcmp guest at the same on the same slot will impact cpu resource or other impact ?
example
Guest A on slot 1 and 2
Guest B on slot 1 and 2
If i upgrade at the same time will impact ?
thanks
Hi  @Anzine  ,
Follow this article : https://my.f5.com/manage/s/article/K75476930#01_01_link
it contains detailed steps for vCMP systems Upgrade.
>> you must upgrade only one guest per slot , so you can’t upgrade at the same time.
you can find this in the vCMP upgrade considerations
