Updated FirePass SDK Posted
We’ve just updated the version of the FirePass SDK on the
If you have downloaded the SDK and need the FirePass client library, this version includes it.
-Joe
It seems there have been some trouble finding the client side library in the included SDK. Take a look at the SDK Components section of the SDK and it will detail the location of the library in the SDK distribution as well as directions on downloading it directly from your FirePass device.
;Posted By Joe on 10/21/2004 8:56:26 PM
I downloaded the SDK, but when I try to view default.htm, the table of contents (left nav) is unavailable for some reason. (See attached screenshot.) Any ideas why it would fail this way? I downloaded the iControl SDK and the Table of Contents worked fine. I deleted it before downloading the FirePass SDK. Could that sequence of events be the cause? Please help. Anxious to get started. Thank you! --Bradley
I had the same error using IE. Couldn’t figure out why and got tired of playing with IE options. I think it’s java related issue. In any case, I went out and download the Firefox browser and was able to view the API documentation.
Brad and Rick-
We apologize for the inconvenience. I am working with our developers to reproduce and determine if/how to resolve this ASAP.
Thanks for your patience and we hope to have this sorted out shortly as we want you to be successful with the API.
Regards,
- Jeff
