Hello,
Can I have two HTTPS load balancers sharing the same public IP but using different SSL certificate types: one HTTPS with Custom Certificate and another one HTTPS with Automatic Certificate?
I don’t have any issues with the HTTPS with Custom Certificate one, but creating the second one gives VIRTUAL_HOST_PENDING_A_RECORD message for some days.
Thank you.
Hello @Teddy_Brewski
First of all lets clarify you a speaking for XC.
Yes you can have many LBs you using the same IP
But in order to have automatic ceritificate you have to crate an A record or CNAME pointing to the F5 XCIP or URL accordingly and and another CNAME for the automatic certificate validation.
Have you created them?
Thank you @Injeyan_Kostas
Yes indeed, I’m talking about XC.
I did create an A record (tried CNAME too), but it didn’t really help.
May be I need to provide a little bit more info.
So, I have a load balancer with the Custom Certificate option selected. It has a wildcard certificate attached to it covering *.mydomain.org. No issues here -- everything works fine.
I created another load balancer and would like to use Automatic Certificate option this time. I defined one domain entry in the second load balancer: sitea.mydomain.org. I created an A (and CNAME) entries, but VIRTUAL_HOST_PENDING_A_RECORD is still there.
I think my first load balancer takes the priority now since it has a wildcard certificate.
There is a specific CNAME for cert needed
Have you created it?
this from my tenant
just reproduce the exact same thing
it took ~5min for the auto cert
I confirm that the CNAME and A records were created. Unfortunately, it doesn’t seem to help in my case.
Case closed -- CAA DNS entry was missing.
Thank you all!
Should I mention that I told you specifically for this record?
I thought you were referring about _acme record?
My bad
Yes I was talking about acme record but after reading again you post I see it was not the case.
Actually I was not even aware of caa record.
Thank you for letting us know. I learned something today
