TLS/SSL weak messgae auth on code cipher suites
hello,
i have received a vulnerability for our published services for the subject weak ciphers.
Cipher suites: DEFAULT:!DHE:!RSA:!DES:!3DES is configured with TLSv1.2 enabled.
How to resolve any help would be appreciated.
you could use this:
DEFAULT:!DHE:!RSA:!DES:!3DES@STRENGTH
it will order SSL ciphers by strength
then you have to see which ciphers appear to be weak when you scan your virtual server using qualis
And then remove them  just like you removed 3DES for example ,
