I often have a problem with tcpdump on clustered devices. If I e.g. start a dump like this:
‘tcpdump -ni 0.0:p host 192.168.1.1’
the terminal is flooded with messages like these every few microseconds:
13:20:56.003601 IP 1.1.1.2.44098 > 1.1.1.1.cap: failover_packet {
failover_packet_cluster_mgmt_ip ip_address 10.10.10.10
failover_packet_slot_id uword 0
failover_packet_state ulong 5
failover_packet_sub_state ulong 0
failover_packet_monitor_fault ulong 0
failover_packet_hop_cnt uword 2
failover_packet_peer_signal ulong 0
failover_packet_version ulong 2
failover_packet_msg_bits ulong 2
failover_packet_traffic_grp_score ulong 8386
failover_packet_device_load ulong 2
failover_packet_device_capacity ulong 0
failover_packet_traffic_group_load ulong 2
failover_packet_build_num ulong 3944176344
failover_packet_next_active ulong 1
failover_packet_traffic_grp string `/Common/traffic-group-1`
failover_packet_previous_active ulong 1
failover_packet_active_reason ulong 0
failover_packet_left_active_reason ulong 8
out slot1/tmm0 lis=
It’s a little annoying, since with the 0.0:p I want to see the packet on client and server side (which SNAT-IP it uses, which member) - so the only possibility to get rid of it is to constantly exclude with grep -v
Am I doing something wrong about TCPdump?
Or is there any flag that disables these messages?
Or is this due to a wrong configuration of the F5 itself?
Or is it intended behavior?
