SSH vulnerability hptfix installation
Hi Friends,
I am planning to install hotfix on our F5 to make IOS not vulnerable.
my current IOS version is as below.
[admin@STG1F5LDB01:Active] ~ tmsh show sys license
Sys::License
Licensed Version 10.2.0
Registration key KAFBG-NZWGV-BJYLE-GUZLY-ULRZALO
Licensed On 2011/11/04
Service Check Date 2011/11/04
Platform ID D63a
Appliance Serial Number bip221875s
Active Modules
ADD 100 MBPS COMPRESSION (BYQPEOS-AGQNRNY)
BIG-IP LTM 6400 (JBJGWHS-TCPSBKO)
Local Traffic Manager Module
ADD 5 MBPS COMPRESSION
ADD SSL 100
I am following procedure and files as described in following link.
I need your support to understand if I am referring correct link and contents to do so.
Also i need to understand rollback process if this installation fails.
Thanks in Advance
Kalpesh
Doesn’t look like the 6400 is vulnerable according to the f5 post.
The following platforms are affected by this issue:
    VIPRION B2100, B4100, and B4200
    BIG-IP 520, 540, 1000, 2000, 2400, 5000, 5100, 1600, 3600, 3900, 6900, 8900, 8950, 11000, and 11050
    BIG-IP Virtual Edition
    Enterprise Manager 3000 and 4000
Also, another option would be to install a non-vulnerable release of big-ip. Looks like 10.2.4 is the one to go for. You will have a rollback option here as you can upgrade a spare volume / partition.
Hope this helps,
N
Ohh..Thanks Nathan..I didnt looked at this
