We have configured SNMP alerts in our F5 LTM box using the file: /etc/alertd/alert.conf. Now, there is a requirement for us to configure alerts whenever somebody disables a pool member manually. The below alerts doesn’t help since it will only triggers when the health monitor status changes. alert BIGIP_MCPD_MCPDERR_POOL_MEMBER_MON_STATUS { snmptrap OID=“.1.3.6.1.4.1.3375.2.4.0.10” } alert BIGIP_MCPD_MCPDERR_POOL_MEMBER_MON_STATUS_UP { snmptrap OID=“.1.3.6.1.4.1.3375.2.4.0.11” } I would like to know the alert name & its corresponding SNMP trap OID for configuring alerts whenever user makes a pool member “Force offline”. Already we have auditing enabled and this info. along with user ID is getting captured. Need to know how this info. can be captured in mails. Can some one throw light on this?
sathish,
If there’s nothing in the alert.conf file then I would check to see what log messages you get (/var/log/ltm) when a pool member is forced offline and configure a custom snmp alert in user_alert.conf.
See the following SOL SOL3727
Hope this helps,
N
