Hi ,
we have 5 VIP we have enable Snat on pool member. can we enable SNAT in this way if traffic coming from 10.0.0.0/8 subnet. Snat should work otherwise not. is there any way with Irule or another way to do that.
A.N
Hi ,
A.N
This should help
when CLIENT_ACCEPTED {
if { [IP::addr [IP::remote_addr] equals 10.0.0.0/8] } {
snat automap
return
An SNAT is specified at the Virtual Server level, not the Pool or Member level. An iRule would be your best bet, something like this;
if { [IP::addr [IP::client_addr] equals 10.0.0.0/8] } {
Use SNAT Automap if client IP is in this range
snat automap
Alternatively, specify a SNAT Pool instead
snatpool name
Stop processing the iRule for this event
return
else {
Stop processing the iRule for this event if no match
return
Sorry Ajmaluddin, didn’t spot your post till I’d saved mine.
But we have only option to enable SNAT on pool level not on VIP level. let me correct if i am wrong
A.N
You can only SNAT at the VIP level. However, if you specify a pool within an iRule you can SNAT differently per pool. Please clarify your requirements.
yes. i am looking for VIP level.
Thanks for your help
just last question . can we add two subnet as source in same IRULE . Like 10.0.0.0/8 and 192.168.2.0/24
Thanks & Regards
A.N
Great. You could add a second like this, there a few other ways you could do it too;
if { (([IP::addr [IP::client_addr] equals 10.0.0.0/8]) or ([IP::addr [IP::client_addr] equals 192.168.2.0/24 ])) } {
snat automap
snatpool name
return
else {
return
This is a longer method but allows for different actions based on the source subnet;
snat automap
return
elseif { [IP::addr [IP::client_addr] equals 192.168.2.0/24] } {
snatpool name
return
else {
return
