Round Robin issues for proxy base clients
HI, i am new for F5 LTM and i a have created a VS and Pool with 4-Mambers, but i am getting Round Robin issues when user want to access this VS, actually i have a Proxy envirnment in my organigation so due to this all user coming through Proxy IP .. when i am checking connection table for pool so client IP address is showing proxy IP address and traffic is only hit member-1 not other members.
Hi Vinay85,
your observed behavior is most likely caused by an Source-IP Session Persistence profile.
When using such a persistence profile, then only the very first request of a given Source IP Address would become load balanced according to your selected load balancing algorythm. Subsequent request comming from the same Source-IP (aka. different client behind the same proxy), would then just stick to the same pool member.
If you need persistence for your application to work, you could experiment with the Cookie-Persistent profiles. In this case each individual client would become load balanced, but then stick to its initial node on subsequent requests (using an HTTP cookie)
Cheers, Kai
Thasnks Kai… so mean to say i need to remove Source-IP session Persistency after that it will be load-balance between Pool-members wuth round-Robin algorithm…???
You should give it a try to fix the uneven load distribution. But keep in mind, that disabling/changing persistency profiles may break your application. So better test those changes before going live… :wink:
