Rewriting Location Header in iRule
Hello everyone,
I’m trying to find a way to manipulate the HTTP::header location.
For each redirection containing a location header from the backend server, I need to rewrite just the host part of the URL following this rule:
If the location contains “http://webserver01:8282”, the iRule should rewrite the host to “https://externallink.com” while preserving the rest of the URL.
For example:
http://webserver01:8282/login should be rewritten to https://externallink.com/login.
Any help to achieve this would be greatly appreciated.
Thanks!
Hi Hamza,
when HTTP_RESPONSE {
    if { [HTTP::header Location] starts_with "http://webserver01:8282"} {
        HTTP::header replace Location [string map {"http://webserver01:8282" "https://externallink.com"} [HTTP::header Location]]
Thanks.
