we have a BIG-IP running 9.3.1 and we’re experiencing the following problem:
a VS is generating and sending TCP segments to clients from time to time but we can’t understand why.
VS is configured as follows:
virtual VS {
destination A.B.C.D:8180
ip protocol tcp
profile http oneconnect tcp-lan-optimized
pool P1
pool P1 {
snat disable
monitor all http
member 10.15.121.103:8180
member 10.15.121.109:8180
clients (which are in a different vlan behind the LB) produce a big amount of traffic hitting the VS but the issue pops up just for a few connections from time to time.
It shouldn’t be due to timeout and also we didn’t notice any server down event when the reset segments were sent.
I checked all cases when reset are sent, but nothing seems to match to what we have in place.
Is it possible to create an iRule which logs the reset frames or explains somehow the reason of it?.
The LB_FAILED event shouldn’t occur since we can’t see any server down event in logs.
When you say TCP segments, what do you mean? Is LTM sending a RST to the client? If so, do you see a corresponding RST coming from the serverside? I’d suggest capturing a tcpdump with the client and serverside traffic together to compare what’s happening on both sides of LTM. If you need help capturing or analyzing TCP dumps, you can check the following solution or open a case with F5 Support:
SOL411: Overview of packet tracing with the tcpdump utility
Note that it is not possible to use an iRule to log TCP flags on individual packets.
we have already snooped both on clientside and serverside: we didn’t notice any TCP RST coming from servers so it seems that it is the LTM itself generating them.
It happens from time to time, consider that we had just 5 resets on about 1 million connections, but when it happens we loose traffic so it’s not acceptable.
We tried to avoid using oneconnect, but resets are still present.
