Replace Secondary Unit
What is the best method to replace the faulty unit in HA environment.
I’m planning to - Re-ip & cofigure failover and Sync ..
Any other alternatives please…
You need to either consult F5 support or use go the following Ask.f5.com support knowledge base link
I hope this helps
CB
As an alternative for step 7 on SOL8086 from CB, if the faulty unit is still accessible, transfer /config/bigip_base.conf to the new unit and do ConfigSync.
CMIIW …
