RDS Gateway Persistence?
Going through the RDS Deployment Guide and I’m a little confused about how to setup persistence for my Remote Desktop Gateway servers.
The guide gives you an iRule to create, but nothing about creating a persistence profile. However, when you get down to the Virtual Server it tells you to “Select the Persistence profile you created”.
Does the iRule handle this by itself, or do I need to create a persistence profile as well?
Hi James, since the iRule uses universal and source IP persistence, you don’t need a corresponding persistence profile added to the virtual server. We’ll get that corrected in the guide; thanks for pointing it out.
Mike
Great! Thanks for the quick response.
Hi James, we’ve just released version 2.4 of the RDS deployment guide which includes the removal of that extraneous row asking for the persistence profile (http://www.f5.com/pdf/deployment-guides/f5-microsoft-remote-desktop-services-dg.pdf). Thanks for bringing that to our attention.
Joe
