Question on partitions
My current F5 is configured to support an existing customer. I have another requirement to loadbalance few servers for a different customer. Is there a way i can isolate this so that it doesnot mix with my existing account.
Sure, you can create the partition using CLI. if you are on version 11.x and plus; you can use;
tmsh create auth partition partition_name
Based on your configuration, you might have to create Self IP & Vlans under “Common” Partiton.
