Problem Downloading
Hi
I’m having problems downloading a file via Big-IP LTM.
I have created a virtual service HTTP, when i try to download a file directly from de servers there is no problem… but when i try to download it via Big-IP it doesn’t work…
Any clues?
were u able to start downloading?
did it happen on every browser e.g. ie, ff?
Yep all the browsers have the same problem… It doesn’t even starts to download…
web page is working fine, isn’t it? only downloading has a problem, hasn’t it?
can u post your config here?
Everything is working fine…
The only problem is downloading…
I have a load balancing service http between 2 servers… with all the basic options… without irules or persistence…
i’ve no idea. anyway, if i were u, i would run tcpdump and compare packet between server-f5 and f5-client.
the tcpdump command may look like this:
tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap \(host vip and port vport\) or \(\(host poolip1 or host poolip2\) and port poolport\)
