one thing that bother my mind is why disable cookie persistence and use universal persistence (write iRule to use JSESSIONID instead of cookie_persist) , everything work fine.
I think about algorithm of Websphere to process order cookie that lookup for JESSIONID first make this problem, otherwise script that use in apache jmeter is bad.
one thing that bother my mind is why disable cookie persistence and use universal persistence (write iRule to use JSESSIONID instead of cookie_persist) , everything work fine. did you pass bigip’s cookie, i.e. BIGipServer, in subsequent request in jmeter test plan?
Are you actually using the F5 to load balance directly to WebSphere? Or is the F5 frontend’ing IBM’s HTTP server?
The JSESSIONID for WebSphere has multiple parts. The first part is a unique session id for that user/session. Then there can be 1 or more additional parts that have a unique ID for each WebSphere Server. The additional parts are separated by a colon.
Because of how our system is setup we use a combination of the JSESSIONID and then a pool name to create a universal persistence record.
We have multiple applications with separate pools that all share the same same session id. So we break out the session ID and append it with the pool name for that specific application.
