Parameteters in default https monitor
Hi All,
What default parameters are there in monitor /Common/https.
Wanted to know client request header value, server response code if any, send interval, receive interval, success check, failure checks and etc.
@AdityaKurundkar This should easily be visible by going to the health monitors and clicking on the one labled https. The following article has what you are looking for and should be able to search for “HTTPS monitor settings” to find the specific spot in question.
you can also use these:
Thank you
