Hi All,
I have a question about the LTM configuration. I have a pair of F5 LTM’s with Sync issues, I wanted to manually ( Load the config from the Active box) sync the config to the standby box , before I fix the sync issue. Here is my plan,
- save the bipip.conf file on the Active box (tmsh save sys config file var/local/bigip_latest.conf)
- Move this file to the standby unit to the location var/local
- Take the backup of bigip.conf on the standby unit (tmsh save sys config file var/local/bigip_backup.conf).
- Verify the latest config which has been copied from the active box (tmsh load sys config file bigip_latest.conf verify)
- Then load the file , tmsh load sys config file var/local/bigip_latest.conf.
I have two questions , 1. Do i need to perform the merge OR just a load tmsh load sys config file var/local/bigip_latest.conf OR tmsh load sys config file var/local/bigip_latest.conf merge
- Do I also need to move the bigip_sys.config? , If yes , how can I push both the config file.
Thanks, SR
