Multiple Partitions with same route domain
Is it possible to use multiple partition with the same route domain ?
It is recommended to configure each route domain in the separate partition in F5 LTM. Please refer: 404 Page not found | BIG-IP Documentation http://networkingmaterials.blogspot.com/2017/10/f5-route-domains.html
Yes, you can have multiple partitions using the same route domain. Typically used to control administration of different environments within the same route domain.
Check out: DevCentral - An F5 Technical Community
Note that a partition will only see objects created in it and the parent. For example, if you have partitions mystuff-production and mystuff-test, both with parent Common and configured for route domain mystuff-rd, mystuff-production will see objects configured in itself and Common but not in mystuff-test.
