I have 2 DIPs configured with monitors on port 80 working fine.
But the same monitor on port 443 for the same DIPs is showing as Inactive, Down.
Any ideas..would help here.
genseek
genseek
A monitor for port 80 will be configured without security (SSL/TLS). When trying to run the same monitor on port 443, it’s then trying to talk plain-text to an encrypted server. So won’t work.
You need to create a new monitor (Can use the original port 80 for the parent) with security (SSL/TLS) enabled.
H
Here are the monitor configs for port 80 (working) and 443 (not working )
Port 80 - Working Monitor
DeviceA ~ b monitor http_80_Pqr_mn list
monitor http_80_Pqr_mn {
defaults from http_default_mn
send “GET /HeartBeat/Heartbeat.html HTTP/1.0\r\n\r\n”
Port 443 - Not Working Monitor
DeviceA b monitor https_443_pqr_mn list
monitor https_443_pqr_mn {
defaults from https_default_mn
Do you see any difference? What is missing?
have you tried the send string with openssl s_client against https pool member? did it work?
by the way, what bigip version are you running?
nitass,
version is BIG-IP Version 10.2.1 496.43
i did not quite understand -have you tried the send string with openssl s_client against https pool member? did it work?
can you elaborate with example on the new configuration?
e.g.
testing HTTPS with openssl
is there any other reason you can see or have come acrossed, why the monitor with same pool members is working on port 80 and not working port 443?
Port 80 and 443 are responding from F5 on the pool members.
any ideas nitass?
Do you see the HTTPS web service logging anything for the requests?
Do you a receive string configured on the monitor?
As Nitass suggested, can you use ‘openssl s_client -connect 1.1.1.1:443’ and then type in the HTTP request to generate a similar request as the monitor send string? Instead of typing out the \r\n’s, just hit enter.
Aaron
thanks for the response Aaron,
1. Do you see the HTTPS web service logging anything for the requests? - Did not see this but from F5 using tcpdump i can see response coming on port 443 from both the DIPs
2.The monitor status for https for the 2 DIPs shows as Inactive, Down. - Is it necessary that DIPs gateway should be F5 for monitor to work?
If the gwy is upstream router, will the monitor fail?
3.There is no receive string configured on the monitor? - Is the receive string mandatory to be defined?
4. Can you use " openssl s_client -connect 1.1.1.1:443" - you mean execute this cmd from the F5 prompt ?
and for sending request, are you suggesting i use only, " GET /HeartBeat/Heartbeat.htm" and NOT the part “HTTP/1.0\r\n\r\n” ?
Plz confirm.
Going back to the obvious bits… What happens when you try to do the same query with curl from the ltm command line (Bash shell).
curl -kv https://Heartbeat/Heartbeat.htm
H
is the curl command supported on LTM with version 10.2.1?
1. Do you see the HTTPS web service logging anything for the requests? - Did not see this but from F5 using tcpdump i can see response coming on port 443 from both the DIPsit is health monitor traffic, isn’t it? it is not tcp reset, is it?
2.The monitor status for https for the 2 DIPs shows as Inactive, Down. - Is it necessary that DIPs gateway should be F5 for monitor to work?if pool member is able to return health monitor traffic to bigip, it is fine.
3.There is no receive string configured on the monitor? - Is the receive string mandatory to be defined?it is not mandatory.
4. Can you use " openssl s_client -connect 1.1.1.1:443" - you mean execute this cmd from the F5 prompt ?yes
and for sending request, are you suggesting i use only, " GET /HeartBeat/Heartbeat.htm" and NOT the part “HTTP/1.0\r\n\r\n” ?you have to put HTTP/1.0 but \r\n\r\n is just hitting enter twice.
GET /HeartBeat/Heartbeat.htm HTTP/1.0
is the curl command supported on LTM with version 10.2.1?yes
by the way, can you also show us the https_default_mn health monitor configuration?
thanks for the response nitass. Plz see below my replies..
1. It is the response from the pool member and the F5 self IP on the same pool member vlan. I used the below tcpdump cmd to get it
tcpdump -nni 0.0 -X -s0 host 10.41.0.77 and port 80 and host 10.41.0.50
Is thr any other way to check and verify, health monitor traffic?
2. Not sure if pool member is able to return traffic. But am able to telnet on port 443 from F5 to the pool member. Gwy on the pool member is the upstream router IP.
3. What is the command to display the https_default_mn health monitor configuration?
4. One more information - I have another 2 pool members in a different pool having same monitor configured for port 443 and monitor is
working fine.
Could this be pool member server side issue? If yes, is thr a way to check and verify it.
Is thr any other way to check and verify, health monitor traffic?generally, if it is non-floating selfip, it could be health monitor traffic.
3. What is the command to display the https_default_mn health monitor configuration?b monitor https_default_mn list
Could this be pool member server side issue? If yes, is thr a way to check and verify iti think it had better do more troubleshooting e.g. openssl s_client, curl, etc.
monitor https_default_mn {
defaults from https
recv “200 OK”
send “GET /smoketest/test.htm HTTP/1.0\r\n\r\n”
nitass,
Looks like there is a mismatch of “Send string” between the default monitor and the below
Could this be the issue?
Port 443 - Not Working Monitor but the same send string in http monitor is working, isn’t it?
hmm..looks like ..Yes..let me check again..
Meanwhile i executed the openssl cmd an the output as below
openssl s_client -connect 10.11.70.77:443
CONNECTED(00000005)
depth=3 /C=US/O=GTE Corporation/OU=GTE CyberTrust Solutions, Inc./CN=GTE CyberTrust Global Root
verify return:1
depth=2 /CN=Microsoft Internet Authority
verify return:1
depth=1 /DC=com/DC=microsoft/DC=corp/DC=redmond/CN=Microsoft Secure Server Authority
verify return:1
depth=0 /C=US/ST=WA/L=Redmond/O=Microsoft/OU=RXP Security/CN=rxpsws
verify return:1
Certificate chain
0 s:/C=US/ST=WA/L=Redmond/O=Microsoft/OU=RXP Security/CN=rxpsws
i:/DC=com/DC=microsoft/DC=corp/DC=redmond/CN=Microsoft Secure Server Authority
1 s:/DC=com/DC=microsoft/DC=corp/DC=redmond/CN=Microsoft Secure Server Authority
i:/CN=Microsoft Internet Authority
2 s:/CN=Microsoft Internet Authority
i:/C=US/O=GTE Corporation/OU=GTE CyberTrust Solutions, Inc./CN=GTE CyberTrust Global Root
HTTP/1.1 404 Not Found
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Thu, 19 Apr 2012 00:33:40 GMT
Connection: close
Content-Length: 315
Not Found
Not Found
HTTP Error 404. The requested resource is not found.
read:errno=0
for the 2nd pool memebr, openssl gives the following output, getting HTTP/1.1 404 Not Found.What this means?
openssl s_client -connect 10.11.70.78:443
CONNECTED(00000005)
verify return:1
verify return:1
verify return:1
verify return:1
Certificate chain
GET /HeartBeat/Hearbeat.htm HTTP/1.0
Date: Thu, 19 Apr 2012 00:46:20 GMT
Connection: close
Content-Length: 315
Not Found
Not Found
read:errno=0
