I was thinking perl could be used but I’m a bit rusty on it. I’m trying to search up some examples. Do you have any examples that would show any piece of this process?
Which version of TMOS are you using currently??? The iApp feature of the new release gives you the synthetic monitors/Advanced Monitors which will accept a username and password from you and based on that it logs in to analysic which servers is actually serving the client and which one not. I beleive it will help you.
I’m running 10.2.0 code. I did find the deployment guide over the weekend and it looks like I need to be at 10.2.1 to get the right template to do this. Also looks like we need to configure a DNS server for the f5 to query so we can enter the domain / uri into the template.
