Migration advise
Hi Fellow members, I am migrating from vcmp guest ( running ltm + afm) to f5 ve. Both have the identical versions- 15.x. I need advise on the best way to migrate my config over. I am thinking to add the new VE devices into the existing sync-group of the vcmp and then copy the config over, then shutdown the old vcmps.  have a doubt that will this work since one pair is a vcmp guest and other VE, might not even get added into the device group.
Other option is to use the Journeys app and follow instructions from there.
Please advise?
thx
journeys is a good approach, as you can output still non-AS3 if you haven’t adopted yet. But if AS3 is an option for you, you can do journeys there as well or you could also just create a UCS, import that in VSCode with the F5 extension, and explore migration readiness there for AS3. That will prep you for BIG-IP Next as well, as Next is all AS3-based. Now might be as good a time as any since you’re migrating!
I have built the VM’s in vmware - and disabled the interfaces at the vmware level then imported the UCS
load sys ucs platform-migrate MYsystem.ucs
Options:
no-license        no-platform-check passphrase reset-trust
once the devices come up - you can either re-ip the boxes - or do a cutover by shutting down  the old - and bring up the new.
Your VLAN / SWITCH config will need to be spot on at both the physical level - and the vmware level for this to function.
Hello,
As per the below link, there shouldn’t be any issues when adding VE to the cluster:
Thanks,
Mohamed Salah
