Does anyone know what value of measurement is used with the memory pool statistics show under Statistics > Module Statistics > Memory? Is it bits, bytes or something else?
Hi Steve,
I think these are showing the output from tmctl memory_usage_stat and are in bytes.
name
Subsystem object name
allocated
The bytes in memory allocated to the object
max_allocated
The maximum bytes in memory allocated to the object since last system restart
held
The number of objects stored and available for re-use
size
The size in bytes of the object: allocated / current_allocs = size
tot_allocs
Running total number of allocations
cur_allocs
Current number of allocations
Aaron
