Hi
I have few VS configured with source, destination and port as ANY. Its an early configuration, not sure whats the background. I can see traffic on all VS statistics.
Would like to check, is there any way to find our which traffic is transmitted via which VS?
I know source, destination and port of the traffic and can simulate the traffic to verify. Appreciate if anyone can share with me command or possibilities?
Thank you
Jay
@JayanthLakshmipathy I’m not sure if a command exists that would show this because the typical connection table outputs source IP, source port, destination IP, destination port, and destination pool member. I think the only option to look at connections in a reactive way would be to perform a tcpdump with the following flags that would insert F5 information about where the traffic is going.
tcpdump -nni 0.0:nnp host <client_IP> -w /shared/tmp/my_cap.pcap
Hello,
You can filter by the client side IP if need to check which virtual server is selected.
Command:
#show sys connection cs-client-addr 192.168.8.1
Output:
Sys::Connections
client IP virtual server IP source from F5 (self IP) backend server
192.168.8.1:54105 192.168.8.100:80 192.168.7.111:26379 192.168.7.100:80 tcp 4 (tmm: 1)
There are also multiple options in show sys connection that you can check and verify with.
command output explanation:
command options:
Thanks,
Mohamed Salah
Hi Paulius
tcpdump, helped in getting what i need. Thanks very much.
Thank you
Jay
