Today I noticed logging on a BIG-IP VE that I can’t explain. Also I can’t find much about online.
We see the following logging (in a fast rate):
Jul 17 10:44:20 BIGIP-10 info tmm[18302]: 017b0007:6: IVS (connecting from parent 10.10.10.111:443 → :::0): Internal virtual server /Common/Monitor-example.com_ivs is sending HTTP Response
Jul 17 10:44:20 BIGIP-10 info tmm[18302]: 017b0008:6: IVS (connecting from parent 10.10.10.111:443 → :::0): Internal virtual server /Common/Monitor-example.com_ivs is done sending HTTP Response
Jul 17 10:44:20 BIGIP-10 info tmm1[18302]: 017b0004:6: IVS (connecting from parent 10.10.10.162:443 → :::0): Internal virtual server /Common/Monitor-www.excample.com_ivs accepted internal connection
Jul 17 10:44:20 BIGIP-10 info tmm1[18302]: 017b0007:6: IVS (connecting from parent 10.10.10.162:443 → :::0): Internal virtual server /Common/Monitor-www.example.com_ivs is sending HTTP Response
Jul 17 10:44:20 BIGIP-10info tmm1[18302]: 017b0008:6: IVS (connecting from parent 10.10.10.162:443 → :::0): Internal virtual server /Common/Monitor-www.example.com_ivs is done sending HTTP Response
There are no internal virtual servers on the system, log levels are default.
Logging is at a high rate.
Has any of you seen this on their own boxes? And I would like to stop it.
Thanks in advance.
Kees
