Issue in changing IP for syslog server
Hello, I have an issue in SYSLOG server configuration. in our setup, IP of syslog server has been changed. we have changed the syslog server IP also. But still it is device is sending data to old configured IP on port 514. can anyone please tell , where i need to check so that it would not send data to old syslog server
First of, to be sure that you don’t send data to the old server please using CLI process a tcpump:
tcpdump -nni 0.0 dest host 1.1.1.1 and port 514
Where 1.1.1.1 is your old syslog server…
And you can check using GUI that you modify configuration:
  • System ›› Logs : Configuration : Remote Logging
and/or
  • System ›› Logs : Configuration : Log Destinations (check where the destination forward logs in your log destinations profile) if you use it of course.
Keep me in touch
