iControl vs. iApp
I need to understand the basic difference between iControl and iApp. Where can I get basic beginner’s tutorial on these technologies with examples ?
There’s lot of articles in devcentral. You can refer the below main topic’s,
iControl Wiki Home
What is iControl?
iApps Wiki Home
iApp – What is it?
Setup a LAB LTM and playaround with IControl API calls and Iapps templates.
Hi Mayank,
The difference in one sentence.
iApp is used to deploy common applications behind the BIG-IP using templates provided by F5.
iControl, are used to remotly manage configuration of the BIG-IP using API calls
Example of possible operation :
  • create a monitor
  • delete a VS
  • list status of VS
Jaikumar shared good links to start
Regards
