Hi Guys,
Wondering if I can use iCALL to trigger a device failover due to the failure of an F5 BGP Peer ?
Hi Guys,
Yes you can use ICALL to process a failover, but as you know you have to Triggered this call (reacting to a specific event).
Can you tell me how you monitor your BGP peer? pool member monitoring, …
sys icall script failover {
app-service none
definition {
tmsh::run /sys failover standby
Regards
There is a testing method in K14397: Running a command or custom script based on a syslog message.
The process ID in “BGP[13155]” is the reason for the matching failure, for it is not a fixed number. You might want to try something like "
BGP*: BGP: %BGP-5-ADJCHANGE: neighbor IP ADDRESS Down
" instead (I presume that “IP ADDRESS” is a fixed string).
Really appreciate your comments folks - I will try out the suggestions and let you know how I get on…
