I Rules + HTTPs
We have an I Rules configs to allow specific subnets against HTTP & HTTPs VIPs,however ,we noticed that a subnet which is not defined on I rules can browse HTTPs but not HTTP .
Is this a bug or what ?
Regards
Hessam
post some details..
are you SSL offloading HTTPS vips? what event is your rule using? when CLIENT_ACCEPTED will most likely be the event to use if you don’t need to inspect the Layer 7 information.
