HTTPS to Tomcat:8080
Hi
I have the following situation:
CLIENT --> HTTPS --> F5 --> HTTP:8080 --> Tomcat-Server
I’ve created a VIP which handle the SSL-termination. Then I have a server-pool with the tomcat-server, which listen on port tcp 8080.
When I connect directly to the tomcat-server with tcp:8080, then all works fine. When I connect through the loadbalancer with https://, then I got error-messages from the tomcat-server.
I tried with a streaming rule to replace http:// with https:// on the vip → no success.
How do I configure the loadbalancer, to make proper requests to the tomcat-server?
Thanks a lot.
Tom
Hi Tom,
I assume the issue is that tomcat is including http:// and/or port 8080 in references to itself. Can you use a browser plugin like HttpFox for Firefox or Fiddler for IE to see which headers and/or what in the payload is breaking the LTM proxying of the application?
Aaron
Hi Aaron
I installed httpfox and I can see, that the first connect is established with https://. Then I got a redirect (http/302) to “http://”. Is there a f5-way, to solve this problem? Or do I need to solve this problem in the “application”-way?
Thanks a lot.
Tom
You can create a custom HTTP profile with rewrite redirects enabled to fix this on LTM.
Aaron
Hi Aaron
I solved this problem on the application-side:
In the “server.xml” (this is the tomcat-configurationfile), I appended the following parameter to the default-connector-port:
proxyName=“[here you enter the external dns-domain-name]” proxyPort=“443” scheme=“HTTPS” disableUploadTimeout=“true”/>
Thanks a lot for your help.
Tom
That’s even better. Glad you got it working.
Aaron
Tomtux: thanks for posting your solution - we used to run into this frequently back in my prior job, and your solution is preferred IMO. It’s a good one to have in the bag of tricks!
-Matt
