URL client does get request https://branches.test.org/webapp/rest/public/redirect/android
redirect to https://play.google.com/store/apps/details?id=org.penfed.mobile.banking
What version are you on? Before 11.4 you could use an HTTP Class (Local Traffic ›› Profiles : Protocol : HTTP Class). If you’re on 11.4 you can use a Local Traffic Policy.
You could also use an iRule:
if { [string tolower [HTTP::path]] starts_with "/webapp/rest/public/redirect/android" } {
HTTP::respond 302 Location "https://play.google.com/store/apps/details?id=org.penfed.mobile.banking"
Note that I used “starts_with”. This may or may not work in your case (depending an whether any other paths start with “/webapp/rest/public/redirect/android”). However, “starts_with” does get around other issues that often plague redirects (e.g. trailing slashes, inclusion of default file names (like index.html)).
Thank you for your help. We are on version 11.3 The IRULE works as expected
Michael, if it worked can you vote up the answer?
